North LA County Run (Leona and Tule Divide) Oct 28th
BadSquatch
Huge Member
This will be a mostly easy/scenic run on Leona Divide and Tule Divide and after the run we will stop at The Rock Inn for some after run bonding over the beverage(s) of your choice. This is a 2-3 rated trail, however, there is a spot at the end that's going to be a bit tight and off camber where we drop into a creek bed and then climb back out of it. So I'm going to call this more like a moderate (3-4) and recommend at least 33" tires. It's also a family friendly event, so please be aware that there might be children listening to the radio, etc. and keep that in mind.
Please fill out the form located here so that I know who's coming, and for an emergency contact in case something happens. I don't keep this info after the run, it's just for the above informational purposes. I'm limiting the run to the first 15 people who fill out the form in order to keep the group to a reasonable size. The form will also have some additional information, as well as a link to a .gpx file that will show the exact trail(s) we will be following.
