Duff Long Arms w/ 2.5” SL Caster Inquiry
I bought Duff’s long arms just over a year ago and almost motivated to install them. Currently I’m 2.5” SL, 35” tires, stock arms with 4* c bushings. According to last alignment report I’m +1.5* caster (if I’m reading correct) and been seeing on the CB forums that +3.5-6* caster is prime. It drives and tracks great with no wandering. Super cozy at 75-80 mph. I went with 2* bushings and along with their built in 4.25* caster, puts me at 6.25* total vs my 4* currently. So my thought is with my last alignment report, I should be around 3.5-ish positive caster with the new 2* bushings along with the built in 4.25*’s. Any thoughts on this? My math correct? I’m starting to question if I should use my 4* bushings I have now instead of the 2*. 12 Pack just did his with same SL and 2* c bushings, but mentioned his now might be wandering. Everything else up front bushing/ball joint/trac bar/steering is 3 years old.
Everything seems outta whack on the report, but it drives straight and brilliantly. 🤷‍♂️
